TCL Script returns various results
ritchieb
I'm getting varios results from a TCL script that I am running, essentailly the process is
a) pull the updated script via TFTP
b) run script from flash
Sporadically, no results are shown on the console, if the script is then re-run the results are shown and are correct. Attached is a screen shot showin this.
Has anyone seen this before? Any recommendations for TCL settings/enhancements appriciated.
Thanks!
As an update.... I never got to the bottom of this, instead I created another TCL script that simply ran a few show commands and used this one to kick the TCL process into life first, I have not seen the issue since implementing this workaround.
So, process/logic for an automated job from management platform is;
+ Login to device
+ Copy simple script from central location
+ Copy detailed script from central location
+ Run simple script
+ Run detailed script
Seb Rupik
Hi there,
Any chance you can share the contents of the TCL script?
cheers,
Seb.
+ Login to device
+ Run simple script
