TCL Script to change hostnames from upper case letters to lower case
packettracer86
Hey guys,
could someone provide me (not sure if it`s even possible with tcl) a script which changes the hostname of a device from upper case to lower case letters?
The hostname always consits of 5 letters and 3 numbers. e.g ABCDE012
And the script should change it to abcde012.
My goal is to roll it out with a NMS on about ~100 switches.
Thank you in advance!
Joe Clarke
The Tcl code to do this is rather simple:
set hostname [string tolower $hostname]
Then, if it's tclsh you're using:
ios_config "hostname $hostname"
6 Replies 6
Joe Clarke
Hi Joseph,
thank you for the quick response!
Do i have to run this as a event manager applet or how can i execute it?
My Environment:
Hardware: WS-C2960CG-8TC-L
Software: C2960c405ex-UNIVERSALK9-M 15.2(2)E
This is tclsh code.  Just execute tclsh and paste the code in.
Why does it not work? :/
SWITCHNAME#tclsh
SWITCHNAME(tcl)#set hostname [string tolower $hostname]
can't read "hostname": no such variable
SWITCHNAME(tcl)#ios_config "hostname $hostname"
SWITCHNAME(tcl)#tclquit
SWITCHNAME#
I had assumed you already had extracted the hostname into the $hostname variable.  But to do that, use:
set hostname [info hostname]
Hi Joseph,
okay that makes absolutly sense.
Thank you for the support, it works like a charm!
