TCL Script to print Router-ID of every neighbor on a certain interface
astoffel1
This code will do more than print but I am just taking the first steps.
if [catch {cli_exec $cli1(fd) "enable"} _cli_result] {
    error $_cli_result $errorInfo
if [catch {cli_exec $cli1(fd) "show ip ospf neighbor gigabitEthernet 0/0 detail | include Neighbor 10."} _cli_result] {
set _ospf_neighbors [regexp { Neighbor ([0-9]+)\.([0-9]+)\.([0-9]+)\.([0-9]+)} "$_cli_result" match 1st_8et 2nd_8et 3rd_8et 4th_8et]
action_syslog msg $1st_8et.$2nd_8et.$3rd_8et.$4th_8et
 Right now my output only gives the first router-id, any idea how I would print 2 or more router-ids?
Joe Clarke
You can iterate over the lines:
foreach line [split $_cli_result "\n"] {
   set _ospf_neighbors [regexp { Neighbor ([0-9]+)\.([0-9]+)\.([0-9]+)\.([0-9]+)} "$line" match 1st_8et 2nd_8et 3rd_8et 4th_8et]
Joe Clarke
Thank you very much Joseph, you are the MVP for TCL. Just started using it, been poking around the forums here for some example seems like you always point people in the right direction.
My question is any documentation you would recommend ?
I recommend any general Tcl site (like tcl.tk) or book to learn the language.  We use standard Tcl 8.3.4, so getting a solid foundation in Tcl will help.  Besides the Cisco.com docs on "EEM Tcl" that you can find with Google, have a look at https://supportforums.cisco.com/document/48891/cisco-eem-best-practices .  That will provide much more insight into the capabilities of EEM.
