Telemetry failure with Prime Infrastructure 3.8
a-moreau
I have some issues with telemetry connection between my controller C9800-L-F-K9 (v. 17.3.2a) and my Prime Infrastructure 3.8.1 which have the last Device Pack. The controller appear in Prime but not AP which are C9120AXI-E (AP Discovery Status : "Not Yet Completed" and Telemetry Status : "Failed").
With a "show telemetry internal connection" in the controller there is nothing in output.
What is wrong ? What is the problem ?
6 Replies 6
marce1000
 - You are probably hitting this bug :
            https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvv04560/?referring_site=ss&dtid=osscdc000283
 M.
adventurer
Is this bug public viewable ? Somehow my account gives a access denied
Maybe I'm also hitting the same bug. Can someone post the resolution here. Thanks.
 - Seems to be a general problem for the moment, can not enter 'global' bug search with the same error.
 M.
 - Refhttps://bst.cloudapps.cisco.com/bugsearch/bug/CSCvv04560
   It seems like  the bug search tool is online again , apparently it got a face-lift too....
 M.
this is a bit difficult to troubleshoot, since we don't know how you set up the connection between the controller and Prime.
You might want to have a look at the document linked below and check if you executed all the steps necessary...
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/214286-managing-catalyst-9800-wireless-controll.html
adventurer
Thanks for the replies.
My issue is not the same as the bug ID.
I have figured out need a local user account with read & write on the c9800, for Prime to use. Then it'll work.
