Telneting to Cisco Secure ACS 1113 ver1
How is it possible to configure the telnet/ssh in ACS1113 device through web interface or through the console? Is it required to restart the device to enable the configuration? Is it will be similar to the telnet configuration on routers ? Kindly provide the configuration details if it has to be done through console.
How is it possible to access the ACS1113 device except console / webinterface.
You must use serial interface or WEB interface.
There is no another way.
Best regards.
Massimiliano.
Is it possible to enable telnet to this device?
