SNMP Mib OID
maryodriscoll
I am receiving an OID alert in from some Cisco Metro 3750 switches. Summary of OID is 1.3.6.1.2.1.14.16.6.10. On the MIB tree, I get as far as 13.6.1.2.1.14 which is the OSPF tree but it only goes as far as 15 which is ospfConformance. Any ideas on how I can translate this OID?
Show ver
Metro_3750#sh ver
Cisco IOS Software, C3750ME Software (C3750ME-I5-M), Version 12.2(25)EY3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Fri 02-Sep-05 08:07 by myl
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750ME Boot Loader (C3750ME-HBOOT-M) Version 12.1(14r)AX, RELEASE SOFTWARE (fc1)
Metro_3750 uptime is 33 weeks, 3 days, 3 hours, 14 minutes
System restarted at 12:15:34 GMT Fri Jan 11 2008
System image file is "flash:c3750me-i5-mz.122-25.EY3/c3750me-i5-mz.122-25.EY3.bin"
cisco ME-C3750-24TE (PowerPC405) processor (revision E0) with 118784K/12280K bytes of memory.
Processor board ID CAT1010N11N
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
1024K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : XXXXXXXXXXXXXXXXXXXXXXXXX
Motherboard assembly number : XXXXXXXXXXXXXXXXXXX
Motherboard serial number : CATXXXXXXXXXXXXXX
Model revision number : E0
Motherboard revision number : A0
Model number : ME-C3750-24TE-M
Daughterboard assembly number : XXXXXXXXXXXXXXXXXXXX
Daughterboard serial number : CATXXXXXXXXXXXXXXXXXXX
Daughterboard revision number : A0
System serial number : CATXXXXXXXXXXXXXXX
Top Assembly Part Number : XXXXXXXXXXXXXXXXX
Top Assembly Revision Number : B0
Version ID : V05
CLEI Code Number :XXXXXXXXXXXX
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 1 28 ME-C3750-24TE 12.2(25)EY3 C3750ME-I5-M
Configuration register is 0xF
Mary
Joe Clarke
I'd have to see the raw trap PDU to be sure, but I'm guessing this is your application's way of saying this is an OSPF trap of general type 6 (enterprise-specific) and specific type 10 which would be ospfTxRetransmit:
ospfTxRetransmit NOTIFICATION-TYPE
OBJECTS {
ospfRouterId, -- The originator of the trap
ospfIfIpAddress,
ospfAddressLessIf,
ospfNbrRtrId, -- Destination
ospfPacketType,
ospfLsdbType,
ospfLsdbLsid,
ospfLsdbRouterId
STATUS current
DESCRIPTION
"An ospfTxRetransmit trap signifies than an
OSPF packet has been retransmitted on a non-
virtual interface. All packets that may be re-
transmitted are associated with an LSDB entry.
The LS type, LS ID, and Router ID are used to
identify the LSDB entry."
::= { ospfTraps 10 }
Ok, that is helpful. What we are receiving is the trap below. OspfTXRetransmits though -
should that be something I worry about as they are occuring very often(or rather the trap is logged often)?
SNMP config on the Metro Switch is as follows:
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
Node AlertKey Summary Manager LastOccurrence Count
Metro_3750 .1.3.6.1.2.1.14.16 6 10 XXXXXXXXXXXXXXXXXXX 02/09/08 10:24:39 439
You may want to ask this on the routing protocols forum.
