Temperature MIB for Cisco 800
sulloas16
Hi!
Could anyone tell me if there is a MIB for monitoring temperature on a Cisco 800?
I've been looking for it but I cannot find it.
If it does exists, where can I get it?
I'll appreciate any useful information
Vinod Arya
I dont think many of c800's have a temperature sensor, being a very small platform, and hence it does not brings information when polled via SNMP for temperature.
Do you see any CLI output for temperature for this device?
That said, mostly CISCO-ENTITY-SENSOR-MIB is used by Cisco devices for temperature and other sensor information.
You can check what MIBs your device has as per IOS from :
http://tools.cisco.com/Support/SNMP/do/MIBSupport.do?local=en&step=3
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Hi Vinod!
The CLI output for temperature on this device shows only the status not the value.
Looking in the link you attached, that MIB (CISCO-ENTITY-SENSOR-MIB) is not supported by this image
Thanks anyway!
