LMS4.2 Error: Unable to connect to Data base
enriqueahj
I have the following message in my CiscoPrime LMS 4.2.2 home portal:
Discrepancies
Unable to connect to Data base.
Probable Cause:
    ANIDbEngine process may be down
and
Best Practices Deviation
Probable Cause:
But when I see the Process Status Report, the process is running:
36.ANIDbEngineProgram started - No mgt msgs  received148400N/ANot applicableNot applicableService was already running
Can you help me with this issue?
Kike Hdez
aparada14
Hi Enriqueahj
have you made a ping test from a PC DOS command prompt to the LMS server Ip address???
Try ping "IP_Address" and try ping "name_serverr"
I´ll wait for your answer
Hi Aparada14
Yes, I can ping the LMS server with the ip address and the name_server.
I can access the LMS service via web, and I can login the service, but in the main window, I have some error messages. See the image below:
LMS is working on Windows Server or Linux Server or any other????
your process ANIDbEngine maybe is not running well, it has the following status in normal condition:
ANIDbEngine           Program started - No mgt msgs received
try in your LMS to start up the process
Hi Aparada
The LMS is installed in a Windows Server 2008 Enterprise.
I restarted the ANIDbEngine process but I have the issue yet. Also, I see that ANIServer process is in "Running with busy flag set" state. Is this normal?
3.ANIDbEngineProgram started - No mgt msgs received148800N/ANot applicable
4.ANIServerRunning with busy flag set12736009/19/2012 3:34:06 PMNot applicable
