Temperature Monitoring
vipinrajrc
Level 3
Level 3
Hi Experts,
I have solarwinds orion in my org. Is there any way to monitor temperature of switches and routers using solarwinds??
Could you please provide the OIDs? or where can i find thses OID????
Vipin
Thanks and Regards, Vipin
Dan Frey
Take a look at the CISCO-ENVMON-MIB for the temp OID.
Dan
ameya_oke
Hi Vipin,
I have recently implemented temp OID, please find the detail below
ciscoEnvMonTemperatureStatusValue
OID: 1.3.6.1.4.1.9.9.13.1.3.1.3
Configure this in Solaris: 1.3.6.1.4.1.9.9.13.1.3.1.3.1
http://www.oidview.com/mibs/9/CISCO-ENVMON-MIB.html
Note: Not all router/switch platform support this OID.
         eg: 2800 support with temp values in degree celcius
               but 1800 only give an output "OK" when command "sh env all" is issued in router.
               7200,6500 has support.
Please rate if helpful.
Ameya
