03-01-2017 06:01 AM
I have a Cisco router running as a Terminal Server for OOB console access to various Cisco devices.
I'm seeing an intermittent issue with ASA console ports where they seem to lock up. When this happens I can see output on the console port, but I can't input anything. A reboot of the ASA cures the problem for a while but the issue returns.
Kind Regards
Terry
03-01-2017 08:44 AM
If you have low level logging turned on for your ASA console, you could be overrunning the input buffers on the console server.
03-01-2017 09:45 AM
Hi Marvin
Thanks for your reply.
I don't have console logging enabled on the ASA's.
When I look at the Terminal Server lines connected to the ASA's I am seeing noise and overruns, however, I am also seeing these on other lines that are working ok.
KR
Terry
