TEST PORT MAC ISSUE
DabITS403
Community Member
I need to be able to test client devices in my ITS lab. I have a static ip specifically assigned for this task,  our lab switch is an IE3000, the issue I believe is arp/mac related as once a device I’m testing is connected I can’t test any other device for an extended period of time essentially restricting us to testing 1 device a work day. This is not conducive to the work flow needed.  Is there a configuration or work around that would allow us to test multiple devices using this single ip.
@DabITS403
After you finish the test with one device, run the following command
clear mac address-table dynamic address mac-address
