Time range access-list problem
aadilovic
Level 3
Level 3
I made this access-list:
Standard IP access list 1
10 permit any (135 matches)
Extended IP access list RadniSati
1 permit tcp 192.168.0.0 0.0.0.255 any eq smtp
2 permit tcp 192.168.0.0 0.0.0.255 any eq pop3
10 permit ip host 192.168.0.40 any time-range RadniSati2 (inactive)
20 permit ip host 192.168.0.42 any time-range RadniSati2 (inactive)
30 permit ip host 192.168.0.50 any time-range RadniSati2 (inactive)
40 permit ip host 192.168.0.51 any time-range RadniSati2 (inactive)
50 permit ip host 192.168.0.52 any time-range RadniSati2 (inactive)
60 permit ip host 192.168.0.57 any time-range RadniSati2 (inactive)
70 permit ip host 192.168.0.58 any time-range RadniSati2 (inactive)
80 permit ip host 192.168.0.59 any time-range RadniSati2 (inactive)
90 permit ip host 192.168.0.60 any time-range RadniSati2 (inactive)
100 permit ip host 192.168.0.9 any time-range RadniSati (active) (16 matches)
110 permit ip host 192.168.0.10 any time-range RadniSati (active)
120 permit ip host 192.168.0.12 any time-range RadniSati (active)
130 permit ip host 192.168.0.111 any time-range RadniSati (active) (573 matches)
140 permit ip host 192.168.0.153 any time-range RadniSati (active) (190 matches)
150 permit ip host 192.168.0.15 any time-range RadniSati (active) (9 matches)
160 permit ip host 192.168.0.16 any time-range RadniSati (active)
170 permit ip host 192.168.0.14 any time-range RadniSati (active)
180 permit ip host 192.168.0.24 any time-range RadniSati (active) (170 matches)
190 permit ip host 192.168.0.20 any time-range RadniSati (active)
200 permit ip host 192.168.0.21 any time-range RadniSati (active) (3 matches)
210 permit ip host 192.168.0.3 any time-range RadniSati00-24 (active) (669 matches)
220 permit ip host 192.168.0.23 any time-range RadniSati00-24 (active) (199 matches)
230 permit ip host 192.168.0.61 any time-range RadniSati00-24 (active)
240 permit ip host 192.168.0.82 any time-range RadniSati00-24 (active)
250 permit ip host 192.168.0.41 any time-range RadniSati00-24 (active) (3 matches)
260 permit ip host 192.168.0.62 any time-range RadniSati00-24 (active) (12 matches)
270 permit ip host 192.168.0.65 any time-range RadniSati00-24 (active)
280 permit ip host 192.168.0.66 any time-range RadniSati00-24 (active) (48 matches)
The problem is that this ACL is working only for 2 days and then it stops. I have then to take the acl out of the interface and put it back in.
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip access-group RadniSati in
ip nat inside
ip virtual-reassembly
Router is 876 and IOS c870-adventerprisek9-mz.124-6.T5
gmarogi
Level 9
Level 9
The time range relies on the software clock of the routing device. For the time range feature to work the way you intend, you need a reliable clock source. We recommend that you use Network Time Protocol (NTP) to synchronize the software clock of the routing device
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087ae5.html
Can you post the time range configuration?
What type of router is this and when ACL doesn't work were you seeing any problems like high CPU etc..?
