timeout on IPSLA
Xiao Guai
In the IPSLA settings, is it possible to enable object tracking on the router with the example settings in the below?
(I would like to know if the router with the setting below can enable object tracking when the router couldn't get response packets from the destination IP three times in a row after sending icmp-echo packets at intervals of 10 seconds)
ip sla 1
icmp-echo x.x.x.x source-ip y.y.y.y
frequency 10
timeout 30000
ip sla schedule 1 life forever start-time now
track 5 ip sla 1 reachability
 three times in a row after sending icmp-echo packets <<-
the config you share is simple icmp-echo
in icmp-echo the router send ONE icmp  and waiting it back in specific time (timeout) if it not back then the IP SLA is timeout and track is down
what you want three lost in row can done by icmp-jitter or path-jitter
but sorry  I couldnt find example until now how we can make ip sla and track down when three (not one) packet loss (timeout)
If I get anything I will update you
MHM
