TLS/syslog issue
jrh
Level 2
Level 2
I am trying to configure syslog to use TLS on my ASR (IOS XE 16.9.4) and the config doc I am looking at says that BEEP should be a transport option but I only see TCP and UDP. Is there something else I need to enable to see BEEP as an option?
balaji.bandi
what is the version of code running on ASR
try below syntax :
logging host x.x.x.x transport beep port 600 ?
 (make sure your Syslog server BEEP compatible).
BB
I am running version 16.9.4.
BEEP is not a transport option, just TCP and UDP.
