Tomcat Service not Starting
JPDisney01
We have a problem, that started around the end of July im still trying to investigate...
I can forcebly start the Apache server, but this only produces a holding page saying...'Waiting for service to start' or words to that effect...
Are you running this on a windows 2000 Sp4 box? As we had some security updates applied (230709):
Restart Required:
- Security Update for Windows 2000 (KB961501)
- Security Update for Windows 2000 (KB970238)
- Cumulative Security Update for Internet Explorer 6 Service Pack 1 (KB969897)
- Security Update for Windows 2000 (KB968537)
Running:
cwjava -cw NMSROOT com.cisco.nm.cmf.jrm.jobcli
Gives:
Unable to launch JVM
Java:
Version 1.5.0 (build 1.5.0_20-b02), although this was only added after viewing it as a recommendation in:
Diagnosing Problems With CiscoWorks Server, Chapter 10, FAQ's.
PDShow txt attached
Help please!!!
10 Replies 10
Joe Clarke
Post the output of pdreg-l Tomcat, the NMSROOT/MDC/etc/regdaemon.xml, NMSROOT/MDC/tomcat/logs/stdout.log, any errors in the Windows Event Viewer, and any hs_err* files under NMSROOT.
FYI, we have been seeing a rash of these problems in TAC, and all affected customers have had Sophos anti-virus installed on the LMS server. There is a known problem with Sophos and Java which is affecting more than just LMS. The current workaround is to uninstall (not just disable) Sophos from the LMS server. Afterwards, reboot, and Tomcat should start. Sophos should already be aware of this, but you should contact them as well to see if a better fix exists.
jclarke - Any chance you can provide more info on this known issue???
Here is a thread in the Java forum that explains the issue in more detail:
http://forums.sun.com/thread.jspa?threadID=5399263
Thx
Have uninstalled Sophos, but now cant start the Daemon:
Could not start the CiscoWorks Daemon Manager Service on Local computer. ther service did not return an error. This could be an internal Windows error or an internal service error. If the problem persists, contact your administrator.
As stated there are no errors in the Event Viewer.
What version of LMS is this, and on what version of Windows?
Sorry, I think you said this is Windows 2000 SP4, so this must be LMS 2.6.
Try running NMSROOT\setup\support\resetCasuser.exe to regenerate the casuser password. After running that, try starting Daemon Manager.
Cheers...head not on straight this morning had done this 3-4 times already, but hit '3' each time...no wonder ;O)
No Sophos articles as of yet :O(
