Too many output drops
joel
I notice too many output drops on my router's multilink interface. What does this mean and what could be causing this?
Software Version: c3745-ipvoicek9-mz.124-10b.bin
Problem Details: 3745#sh int multilink 1
Multilink1 is up, line protocol is up
Hardware is multilink group interface
MTU 1500 bytes, BW 3072 Kbit, DLY 100000 usec,
reliability 255/255, txload 31/255, rxload 8/255
Encapsulation PPP, LCP Open, multilink Open
Listen: CDPCP
Open: IPCP, loopback not set
Keepalive set (10 sec)
DTR is pulsed for 2 seconds on reset
Last input 00:00:08, output never, output hang never
Last clearing of "show interface" counters 3w0d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 510015
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 97000 bits/sec, 128 packets/sec
5 minute output rate 384000 bits/sec, 144 packets/sec
97055282 packets input, 2198805340 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
100573061 packets output, 2464703235 bytes, 0 underruns
0 carrier transitions
andrew.burns
Level 7
Level 7
In the absence of any other errors it looks like a simple case of over-subscription. The number doesn't mean much by itself, you need to look at it as a percentage, and in your case it's 0.5%
This may be OK, or it may be causing you issues already but without more context it's hard to say.
Andrew.
Thanks Andrew!
I am going to try increasing the output queue to 128.
Before you do that you might want to read the following doc which gives some more detailed info on troubleshooting output drops:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml#topic4
Enabling WRED on the interface could give you a better solution, but bear in mind that you probably won't be able to eliminate the drops, only manage them better.
Andrew.
Thanks for the link Andrew.
