Tool to monitor broadband speed - regular interval
nomykhan
I would like to check for the best tool to continuously monitor your broadband speed.
A log should be kept to analysis.
The objective is to check the performance of the connection  on a certain period.
Freeware is preferred.
regards,
dukenuk96
Level 3
Level 3
what exactly do you mean under "broadband speed"? Current utilization or maximum possible speed from one end to another?
