Topology OSPF ACLs Access Control Lists
iDAMedic
The file has the following settings
1. Settings.
Step 1. Configure the basic aspects of the devices: PC, router and switch.
Step 2. Configure OSPF routing on R1, ISP, and R3.
Step 3. Verify connectivity between devices.
2. Configure and verify numbered extended ACLs.
The company has a web server with the address: 209.165.200.254. The security policies are as follows:
Allow access to LAN hosts 192.168.30.0
Allow access to host 192.168.20.254
Deny access to LAN hosts 192.168.40.0.
Allow access to all people in the company.
3. Configure and verify numbered extended ACLs.
Match high-volume traffic and reject previously blocked traffic in the ACL. This approach ensures that packages are not compared to subsequent declarations.
Consolidate multiple permission and denial statements into a single statement using intervals.
Consider denying a particular group instead of allowing an opposite and larger group.
DCE Synchronization settings, as appropriate to the connected interface, at 128000 kb / s
Perform addressing and routing with the OSPF Protocol, with Autonomous System number: 20, and with Area Number: 0
Verify End-to-End Connectivity.
iDAMedic
Hi, you already realize the topology, OSPF and ACLs Access Control Lists, but I do not have connection in all the computers, they can help me to check the error and the configuration, thanks.
