Traffic Shapping
mmubarak
Community Member
I have Cisco 877 ADSL router and 8Mbps bandwidth, I have 2 subnets on my LAN for each subnet I want to dedicate 4Mbps.
Weather it can be done by policy map or traffic shapping.What is best configurations to apply on Cisco 877.
a-vazquez
Level 11
Level 11
Traffic policing propagates bursts. When the traffic rate reaches the configured maximum rate, excess traffic is dropped (or remarked). The result is an output rate that appears as a saw-tooth with crests and troughs. In contrast to policing, traffic shaping retains excess packets in a queue and then schedules the excess for later transmission over increments of time. The result of traffic shaping is a smoothed packet output rate.
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a00800a3a25.shtml#policingvsshaping
I need exact configurations for Traffic Shaping and Policy Mapping for
Cisco 877,as tried but with no result.
Vlan1 is having local IP with inside nat.
Hi Mohammad,
The link given to you almost would've done the job except it didnt explain adding the policy to the interface.
I've indicated the steps and necesary config for you below.
First you need to identify the traffic to police:
ip access-list extended SOME_TRAFFIC
permit ip x.x.x.x x.x.x.x x.x.x.x x.x.x.x
class-map TRAFFIC_TO_SHAPE
match list SOME_TRAFFIC
Next define your policy:
policy-map SHAPE_TRAFFIC
class TRAFFIC_TO_SHAPE
shape average 4000000
Apply your policy:
config-if)#service-policy output SHAPE_TRAFFIC
Scott
