Trigger on syslog on hourly occurrence
Hi.
The MWR2900 router has a known bug for Marvel chip, which causes the CPU utilization to spike.
https://tools.cisco.com/bugsearch/bug/CSCtz75800
The workaround is the command "clear mac-address-table secure"
I've written the following EEM applet to issue that command upon the Marvel syslog:
event manager applet MARVEL
event syslog pattern "%MWR2900MRVL_FLTMG-5-EVENT_WARNING"
action 1.0 cli command "enable"
action 2.0 syslog msg "MWR2900MRVL: Marvell Chip Bug detected"
action 3.0 cli command "clear mac-address-table secure"
I would like this applet to trigger only once an hour, regardless of the number of related syslogs (%MWR2900MRVL_FLTMG-5-EVENT_WARNING).
How can this be accomplished.
Thanks for any assistance.
Joe Razionale
6 Replies 6
Joe Clarke
Change the event line to:
event timer watchdog time 3600
Joseph,
I'm hoping to trigger on that exact syslog pattern.
I'm trying to prevent multiple executions of the script.
Joe
Ah, I misunderstood.  There are a number of ways you could do this.  One thing that might be easiest is to configure two applets:
action 4.0 cli command "config t"
action 5.0 cli command "event manager applet MARVEL"
action 6.0 cli command "event none"
action 7.0 cli command "exit"
action 8.0 cli command "event manager applet MARVEL-countdown"
action 9.0 cli command "event timer countdown time 3600"
action 9.1 cli command "end"
event none
action 2.0 cli command "config t"
action 3.0 cli command "event manager applet MARVEL-countdown"
action 4.0 cli command "event none"
action 6.0 cli command "event syslog pattern %MWR2900MRVL_FLTMG-5-EVENT_WARNING"
action 7.0 cli command "end"
Joseph,
Upon further thought, there may be another solution.
Is it possible to add a condition before executing any of the "action" statements?
This script should only run if CPU utilization is high (above 75%).
This might prevent multiple triggers of repeated syslog messages.
Example:
Thank you for any assistance.
Joe
You could do this with SNMP or CLI.  SNMP would likely be easiest:
action 0.1 info type snmp oid 1.3.6.1.4.1.9.9.109.1.1.1.1.6.1 get-type exact
action 0.2 if $_info_snmp_value ge 75
action 4.0 end
Thanks for the input, Joseph.
I'll give it a try.
