Using SecureCRT to run vbs VBscript to erase multiple routers and switches from one Windows PC.
Cannot break machines into rommon mode using a a) vbs script running b) in multiple windows. Using an access server I run 8 open sessions and often times if I power on all 8 machines at once, running the same script, only one of the machines will break. When I run the script on one machine at a time they all break but not on multiple machines. It seems like the break signal is not reaching the other machines and no sign it is being received on the terminal. When I see the script fail to break the machines I can manually break it from my keyboard easily every time.
Please offer any suggestions.
Much trouble sending break signal to multiple Cisco devices vbs vbscript over terminal server
