Trouble setting up snmp by using Packet Tracer
yukiko889
I'm setting up a Catalyst 3650's config by using Cisco's application Packet Tracer for inspection of production network.
But facing some troubles. I'm trying to set SNMP setting as below though, the Swith won't accept the command below. If you have any suggestions to solve this problems,please let me know about it. I'd really appreciate your help.
[SNMP setting command]
snmp-server community TEST RO 1
snmp-server host xx.xx.xx.xx version 2c TEST
[error message]
% Invalid input detected at '^' marker.
-the ACLs have been already set as below.
access-list 1 permit 10.1.1.1
LaserNinja
I tried it also in Packet Tracer and it doesn't seem to be supported. Tried it on a real router and it works fine.
