04-24-2019 10:45 PM
We started to use APIC-EM for massive hardware lifecycle and now we have more that 1000 devices in inventory.
APIC-EM server is a VM : 12 vCPU's, 64 GB RAM and 500 GB HDD. APIC-EM Version 1.6.3.30018. However after about 700 devices are being provisioned system performance started to degrade. Now I see that CPU is 100 % and RAM almost 100% in use.
Question: is there way to tune APIC-EM? Turn off all services except PNP, device discovery and device inventory?
Another question might be related to that issue : As number of APIC-EM administrators increased so someone removed Project with 70% of all provisioned devices and now all these devices are in Unclaimed state. Is there way to bring them back via API somehow ?
04-25-2019 12:34 AM - edited 04-25-2019 12:38 AM
Hi there,
I can't help with your performance question, but I would instinctively say no. @aradford might be able to advise when he's online.
Regarding the the lost project issue. If you do a GET /pnp-search with a 'state': 'UNCLAIMED', do the device objects contain a 'site' object referencing the old project name? If so, try recreating the old project with exactly the same name and it *may* repopulate.
I had a similar experience with APIC-EM when I was using it a while back, and it seemed very sloppy in the way it tidied objects when parent groups where removed:
...you might be lucky!
cheers,
Seb.
04-25-2019 01:16 AM
Unfortunately this doesn't work. I created same project name but all devices appeared in Unclaimed state.
04-25-2019 02:53 AM
So I was able to add Unclaimed device to Project from API using : POST /pnp-project/{projectId}/device. I was using payload '
[{"serialNumber": "FCW2XXXXXX", "hostName": "switch-1", "platformId": "WS-C2960L-48PS-LL", "state":"PROVISIONED"}]
But state of this devices changed to Error - "ERROR_DURING_TRUSTPOINT_PROVISIONING" I'm wonder is there a way to change this status to Provisioned ?
I tried to update device using PUT /pnp-project/{projectId}/device using payload :
[{"state":"PROVISIONED",
"stateDisplay":"Provisioned",
"id":"558590ef-50dc-4f7c-b6a5-XXXXXXXXX"}]
But nothing changed.
04-25-2019 12:39 AM
here is the Troubleshooting Guide to start with :
04-25-2019 07:43 AM
re performance. What is the Disk IO?
Most of the issues i have seen have been IO related.
If you run the following command on the APIC-EM CLi. you should get the disk IO. Below is a bad example of 23M of IO.
04-25-2019 09:16 PM
Got this:
512+0 records in
512+0 records out
536870912 bytes (537 MB) copied, 1.19586 s, 449 MB/s
I think it is not too bad.
04-27-2019 10:36 PM
04-29-2019 12:18 AM
I tried, but I don't have support contract for that.
