Turning on/off port with UDP command
PaskB
Hi all, I am no expert in network, I am learning.  I have this project here where I am using a cisco SF350-24p. And I have a device that interfere with another (outside the network) where to turn off the device on a specific port at a specific moment would give me access back to the other device.
I was wondering if there is a way to turn off a physical port(the physical rj45 port connected in the front) with a UDP command?
The device is connected and uses POE, so disabling the POE over UDP would also work.
Any hint on that would be greatly appreciated.
Mark Elsen
     - What do you mean by a 'UDP command' ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
udp command is used to send and receive UDP datagram messages over an IP network.
I use it to control equipment sending packets.  In example for a video projection connected on a network to power off at the end of the day thru an automated system.
                 - udp is  a data transfer protocol ,  you can not use it to control ports.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
SNMP uses UDP as transport protocol. Wake-on-Lan uses UDP as well, so in that sense, UDP can be used.
Which firmware version are you running ? It is a question of finding the corresponding MIB and then using an SNMP application to change the ifStatus OID.
