two interfaces in the same vlan
jcoaguilaj
Frequent Visitor
Frequent Visitor
Hi.
how to configure two interfaces giga in the same vlan (1)?
thanks
Leo Laohoo
That's a wrong example because, by default, switchports are already in VLAN 1.
Let's say you want to put two interfaces into the same VLAN, 20.
Scenario 1:  Old method or "range" command not supported:
config t
interface Gig 0/1
switchport access vlan 20
interface Gig 0/2
end
Scenario 2:  Range command, two ports are adjacent to each other
config t
interface RANGE Gig 0/1 - 2
end
Scenario 3:  Range command, two ports are not adjacent to each other
config t
interface RANGE Gig 0/2, Gig 0/48
end
Marvin Rhoads
^ Like Leo said for layer 2 interfaces.
For layer 3 interfaces, the answer is no. One switch virtual interface (SVI) per VLAN on a given switch.
