TypeError: Cannot read property 'value' of undefined
yasir.shaikh1
I am trying to audit WLC device, but getting this error in Prime. Please check attachment.
Would you please suggest why.
Cheers,
Yasir
5 Replies 5
Jonporter
Any update on this?
I have a similar problem with trying to add an AP to a map.
Running Version: PI 3.1.5 DP7
  - Check your wireless controller software version and wether it's compatible with prime 3.1.5 :
   http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-148422
M.
Yes running the right code Controller: 8.2.141 is compatible with 3.1.5
Opening a TAC case see if that gets me anywhere.
I think I found the issue, you need to force a sync on affected devices and try again...
David Cooper
This has more to do with chrome and javascript I am sure. I work with a Mac, and using safari (ouch!) allows it to work.
