UCS function in network
interfacedy
Folks,
What is UCS in networking? A unified computing system (UCS) is is a converged data center architecture that integrates computing, networking and storage resources to increase efficiency and enable centralized management. UCS products are designed and configured to work together effectively.
I got definition of UCS from a website. but I still cannot understand it completely. Any can explain why we use it by a example, and what is relation between UCS and ACI. Maybe no any relation between both. Thanks
Ambuj M
UCS is just a bigger computer with more memory, more cpu, more storage and pre loaded operating system, for hosting application that 1000s of devices can access simultaneously just like an HP or a dell server but only better
ACI is a network like any other network, but it’s built specifically for data center environment, keeping application performance and security in mind.
hope this helps, there are many resources on YouTube.
-hope this helps-
Georg Pauwen
in addition to the other post, you might want to read up using the links below:
What is Cisco Application Centric Infrastructure (ACI) Security?
https://www.checkpoint.com/cyber-hub/cloud-security/what-is-cisco-application-centric-infrastructure-aci-security/
Cisco Unified Computing System Overview
https://www.zones.com/site/statics/static_page.html?name=partner/cisco/ucs/overview
ACI + UCS: Two ships finally meet
https://blogs.cisco.com/datacenter/aci-ucs-two-ships-finally-meet
interfacedy
@Ambuj M
"  UCS is just a bigger computer with more memory, more cpu, more storage and pre loaded operating system, for hosting application that 1000s of devices can access simultaneously just like an HP or a dell server but only better ... "
It sounds like a server. If so, what is difference between UCS and  server? Thanks
