Ultra POE port
israrahmed99855
Switches required 90watt for one cctv , with ultra PoE from c2960 or 3850 please suggest exact part number if anybody know it
Also i need to know power budget for ultra PoE ? UPoE
kindly suggest
Both I think support max 60 watt
90 watt need c9000 sereis
MHM
can you please check and confirm it with reference.
also can you let me know What is power buget for ultra POE … is it UPOE ?
Yes it UPoE and as you mention it 90.
I Share link in other post check it
MHM
