unable to load IDS MC
ayolawrence
After installing Ciscowork VMS, I have been unable to load any of the installed management centres. When I tried loading ids-mc, the page tries to connect and then times out.
Help fast.
Ayo
didyap
Level 6
Level 6
For adding sensors to ids mc follow the steps :
http://www.cisco.com/en/US/products/sw/cscowork/ps3990/products_user_guide_chapter09186a008018d972.html
Make sure the vms server is in the ids sensors tls trusted host list
you can do a show run on the sensor to see.
adding vms if needed can be done by going to config t
tls trusted-host {ip address of vms}
