Unable to ping to External Internet
Yoram10222621
Hello, I am a student currently taking a networking course in school.
This is the topology I have, where R1, R2 and R3 are DHCP servers for VLANs 10, 20 and 30 respectively. I have configured HSRP between R1 and R2 where R1 is the main router for VLAN10. Laptop1 has a DHCP address from R1. When R1 is connected to the switch below it (DLS1), Laptop1 can ping to the External Internet Server (10.10.10.1) on the top right. However, when I remove the connection from R1 and DLS1 I get the timed out message. HSRP only works when I completely remove the connections of R1 from DLS1 and R3.
I suspect this might be due to static routes I have configured. Here are the commands I used:
This is the addressing table:
VLAN Table:
Laptop 1 Config:
this is definitely due to the static routes you have configured. In the attached, revised file, I am using OSPF as a routing protocol, and the failover works perfectly. Are you required to use static routes ? If so, that is really tedious, since you have to use tracking and possibly IP SLAs to remove the static routes whenever an HSRP event occurs.
5 Replies 5
Yoram10222621
Just to further showcase the problem I am facing:
Ping does not reach 10.10.10.1 when R1 is disconnected from DLS1
But works when R1 is completely removed
post your zipped Packet Tracer project (.pkt) file...
As requested. Thank you.
Ah yes, it is a requirement to use static routes. Although I suspect that it is a requirement as I was taught this during the current semester. And this is just an opportunity for me to show my lecturer that I am able to configure them.
I also did noticed that I got the intended outcome when I simply shutdown down R1 manually.
Thank you for clearing it up!
