Unable to Register Script on Nexus
Hello Community,
I understand that Tcl isn't supported on Nexus 7K, however whenever I attempt to register a script policy and activate it I get the following error message:
ERROR: Unable to open the file
I get this message even though the file is in bootflash:
The command I'm entering is event manager policy vlantest
Any help will be greatly appreciated.
Cheers
Carlton
7 Replies 7
Even when I attempt to run the policy I get the error message:
ERROR: unable to find the policy
Cheers
Exactly what script policy did you register?  Typically all EEM work on NX-OS is done using applets.
Hi Joseph,
I have tftpd a script in bootflash and now I would like register the script but nexus can't find the script
But what is this script?  What are the contents?
It's a simple Tcl script - just to test nexus ability to register a script
Cheers
The Nexus does not support Tcl scripting in EEM.  This will not work.
Ok. That is such a shame.
