Unable to remove upper level device group in Prime 3.6
Someone in my department was playing around in prime and created a bunch of upper level device groups that are not part of the (user defined, location defined, or site) they are an annoyance to have to scroll down below, but when looking at deleting them in the Inventory>Group Management>Network Device Groups, It does not allow an option. Looking for a way to delete these so they are not visible in the device group list anymore.
Julien Whitlock
 I have a similar issue...looking for a solution...
marce1000
 - Could be a bug . your Prime version is already old. Use latest patch for your Prime version, and device pack too. Or use latest Prime version 'completely' , depending on problem-urgency.
 M.
Im actually running the latest 3.8 patch...
