Unable to ssh towards a device
I am unable to access our device a - WS-C3560X - unless i directly plugin to the console.
I was able to ssh to this yesterday but now I can't.
I already generated a new crypto via crypto key generate rsa even removed and added the ip domain-name
I also tried removing the transport input ssh and changed it to transport input all but I still can't access it.
Here's my configuration
line con 0
 password 7 x
 login local
line vty 0 4
 exec-timeout 30 0
 password 7 x
 logging synchronous
 login local
 length 0
 transport input all
line vty 5 15
 exec-timeout 5 0
 password 7 x
 logging synchronous
 login local
 transport input all
Any help would be appreciated here.
13 Replies 13
Leo Laohoo
Does telnet to the switch works or not?
What error message(s) appear when attempting to SSH into the switch?
hi,
telnet doesn't work either. the connection just times out on both telnet and ssh
Can the 3560CX ping the default gateway of the management IP address?
yes it can.
  1. Can the default gateway ping the switch?
  2. Can you ping the default gateway?
  3. Can the default gateway ping you?
Yes to all
Check FW if there are any blocks.
its passes thru, even set it to all just to be sure
there is any NATing device this SW behind it ??
hi, no natting, but there is a firewall but traffic is allowed. the strange thing is its twin switch is fine and can be ssh'ed
FW do NATing ?
yes firewall does natting but i didn't enable it on any of my links
I will share some tips to check SSH issue behind FW
