03-10-2023 03:13 AM
Can you help me for error below:
Log Buffer (4096 bytes):
ed. To disable feature execute 'no vstack' in configuration mode
Mar 9 09:53:43.597: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Mar 9 10:53:47.302: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Mar 9 11:53:57.971: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Mar 9 12:53:59.816: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Mar 9 13:54:03.016: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Mar 9 14:54:07.031: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Mar 9 15:54:08.612: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Mar 9 16:54:08.121: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Mar 9 17:54:09.383: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Mar 9 18:54:17.225: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Mar 9 19:54:17.463: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Mar 9 20:54:17.295: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Mar 9 21:54:20.832: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Mar 9 22:54:21.076: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Mar 9 23:54:30.329: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Mar 10 00:54:31.698: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Mar 10 01:54:38.139: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Mar 10 02:54:46.606: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
03-10-2023 03:37 AM
what is the device model and IOS code running ?
when is this message start getting ? any upgrade ?
check the below bug also :
https://bst.cisco.com/bugsearch/bug/CSCvd36810
03-10-2023 06:09 AM
This is my answer
Model NameWS-C3850-24S
Software (IOS) Ver.16.6.3 Software (IOS) ImageCAT3K_CAA-UNIVERSALK9
started today, March 10, 2023 And no upgrade
03-10-2023 03:32 PM
Just do the command that I have provided and the log entries will stop.
This is in relations to Cisco IOS and IOS XE Software Smart Install Denial of Service Vulnerability which was first published back in 2018.
03-11-2023 02:40 AM
you have do you upgrade and remove vstack config as mentioned
03-10-2023 03:55 AM
conf t
no vstack
end
wr
