Unable to view on CiscoView the PA-A6-E3 atm card on 7206VXR
lcolimoro
I'm running LM2.6
Common Service 3.0.6
Campus Manager 4.0.10
Running ciscoview for a 7206VXR router, it shows all cards except the PA-A6-E3.
Any suggestion?
THNX
7 Replies 7
Joe Clarke
What version of the Rtr7000 CiscoView package do you have, and what version of IOS is this 7206VXR running?
- Rtr7000 21.0 7000 Series Device Package
-IOS running is:c7200-advipservicesk9-mz.124-11.T2.bin
Well, you're not running into the old IOS bug affecting this card, and it should be supported in Rtr7000 21.0. Please provide a walk of the cardTable and entPhysicalTable from this device.
Sir,
I have atthaced the snmp walk for cardTable entPhysical files...
I miss a file.. sorry
I have confirmed that this module is not supported in the Rtr7000 package in this version of IOS. The problem is there was a renumbering of objects in recent versions of IOS, and CiscoView was not updated to support the new card IDs. Development is working on updating the package to provide support.
I have filed CSCsm25432 to track this issue. You can track this bug on Cisco.com to see when a fixed package version is available.
