Unified Operations 2.2 Help
mcecilia
Hello All,
Trying to install an 2.2 Operations Manager software, every time I receive the error about the server locale. I am sure I have US English as locale. Have anybody had this problem before?
Many thanks
pvanvuuren
Level 3
Level 3
Yip, I've seen this one before too.
You need to edit your registry and reboot.
Registry must be:
HKEY_USERS\.DEFAULT\Control Panel\International\Locale = 00000409
HKEY_CURRENT_USER\Control Panel\International\Locale = 00000409
it should work. Goodluck with CUOM 2.2.
Cheers.
pvanvuuren
Level 3
Level 3
Registry must be:
Cheers.
Thanks for the answer. In the mean time I was testing, and you can get the same using windows instead of registry:
Go to Control Panel
Regional and languages option
Advanced
Default user account settings
And mark the checkbox with "Apply ... and the default user profile"
With this you can get the same that you told me in the answer.
Thanks a lot for your help.
