Hello ALL
My question & problem is related to NBAR, I have enabled NBAR on one of my Cisco router Interface using the command line âip nbar protocol-discoveryâ & it discovered bunch of the well known protocols running across my enterprise, but with that it shows huge amount of Bandwidth is eaten-up by unknown protocols.
So, my question is how I can discover that which application are those Unknown protocols? Can you please help me with a way or command to find that?
Thanks for all your help
Vishal
