Unknown traceroute
cm6043
Hi all,
Does anyone know what the following traceroute mean ? I can ping to the ip but can't show the traceroute destination.
Router#traceroute 172.16.1.71
Tracing the route to 172.16.1.71
1 ? ? ?
2 ? ? ?
3 * ? ?
4 ? * ?
5 ? ? *
6 ? ? ?
7 * ? ?
8 ? * ?
9 ? ? *
10 ? ? ?
11 * ? ?
12 ? * ?
13 ? ? *
14 ? ? ?
15 * ? ?
16 ? * ?
17 ? ? *
18 ? ? ?
19 * ? ?
20 ? * ?
21 ? ? *
22 ? ? ?
23 * ? ?
24 ? * ?
25 ? ? *
26 ? ? ?
27 * ? ?
28 ? * ?
29 ? ? *
30 ? ? ?
Router#ping 172.16.1.71
Sending 5, 100-byte ICMP Echos to 172.16.1.71, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms#
Leung Che Man
Leung Che Man
Given what you have told us I believe that the logical conclusion is that the device is not responding to the traceroute. Perhaps it is running some firewall or has some security settings that will not respond to UDP packets to ports that are not active.
Rick
Rick
6 Replies 6
Richard Burts
Leung Che Man
My guess is that the next hop toward that destination is a firewall (or some other device that is examining packets and permitting and denying traffic) and that device is not permitting the traceroute (which from a Cisco router are UDP packets to some high number UDP port). That device does allow the ICMP ping to go through.
What is the device at the next hop?
Rick
Rick
Hi Rick,
A C2960 switch connect cisco router and this device(172,.16.1.71). I do traceroute from cisco router to this device. By 'sh arp', I can guess this device is a dell server. Does the device not allow to be traceroute ?
Leung Che Man
Leung Che Man
If I am understanding correctly your explanation of the topology, then from a layer 3 perspective from the router the device is the next layer 3 hop. If the device is the next layer 3 hop and if traceroute is not working then either the device is not responding as expected or the router is not accepting the response. Is there any kind of access list on the interface of the router?
Can we also verify that the router has a correct route to the device? Can you post the output of show ip route from the router? And perhaps post the output of show arp from the router?
Rick
Rick
Hi Rick,
The device and the router are connected to the same cisco switch with same ip subnet. I think the device is not accept the traceroute.
Router#sh arp | inc 172.16.1.71
Internet 172.16.1.71 169 0022.1954.bb4f ARPA GigabitEthernet0/1
Router#sh ip int brie
Interface IP-Address OK? Method Status Prot
ocol
GigabitEthernet0/0 172.16.200.6 YES NVRAM up up
GigabitEthernet0/1 172.16.1.1 YES NVRAM up up
FastEthernet0/1/0 unassigned YES unset up down
FastEthernet0/1/1 unassigned YES unset up down
FastEthernet0/1/2 unassigned YES unset up down
FastEthernet0/1/3 unassigned YES unset up up
Serial0/0/0 172.16.200.2 YES NVRAM up up
Vlan1 unassigned YES NVRAM administratively down down
Vlan111 172.16.2.1 YES NVRAM up up
NVI0 unassigned NO unset up up
Router#
Leung Che Man
Leung Che Man
Rick
Rick
Hi Rick,
I think I want to contact the end customer to check the setting this device.
Leung Che Man
