Upgrade IOS on CAT 4500 switch
Dave Kozlowski
Issue - tftp'd over the new image.
did the boot system flash etc to update the config
but the old image is still in boot startup.  how do I remove it?
I have tried the
    no boot system flash  etc then end.
    I don't get any errors buts its still in the file.
thanks
Dave
balaji.bandi
have you set the new boot variable to boot with new image
post  the out put :
show boot
dir bootflash:
or
you can follow this guide.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-4000-series-switches/27848-179.html
Make sure you do all the task of upgrading the OS in change window always preferable.
BB
Leo Laohoo
So the old IOS file is still in the flash?
Have you tried deleting this? Maybe the "squeeze" command is needed?
Post the complete output to the command "dir bootflash:".
