Upgrade license validation for RME and DFM
Dear Forum members,
I've installed the follow CW product on a fresh machine:
Product Name : CWLMS-2.5-URUP-K9
Product Description : LMS 1.x, RWAN 1.x, Upg to LMS 2.5.1 UR - Rev Dec05
Well, my customer has bought an uncounted permanent license:
INCREMENT RME cisco 4.0 permanent uncounted
INCREMENT DFM cisco 2.0 permanent uncounted
INCREMENT IPM cisco 2.6 permanent uncounted
INCREMENT CM cisco 4.0 permanent uncounted
In this case, I've to run DFM and RME validation script however?
Leonardo
Martin Ermel
Yes, you have to.
The value 'permanent' states it is not an eval (restricted to 90 days), 'uncounted' means the DCR is not restricted to 300 devices;
and the validate upgrade script tests if you have had the right to purchase the upgrade (which in fact is a full version). It does this by forcing you to present either the 'old' CDs or a running server.
David Stanford
Are you getting a pop up saying that your copy will expire in 90 days? If you do then you need to run the script, if not, then you don't need to.
