Upgrade OpenSSH in Cisco network device (switch,router)
EJ Talamayan1
Hi Guys!
Is there a way to upgrade the OpenSSH of cisco switch or router without upgrading it's software version?
Thanks in advance
Mark Elsen
 - No
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thank you for response
Does it mean that if I upgraded the software version of the network device, OpenSSH will be upgraded as well?
 - Not necessarily, you could check Release Notes for the intended version for that ,although it is a somewhat specific technical item and it usually not mentioned in the Release Notes ,when changed, insights on what version being used in current and or subsequent releases can be obtained with commands such as :
nmap -sS -A -p 22 your_device
nmap --script ssh2-enum-algos your_device
       Beauty and terror
      Just keep going
       No feeling is final
