Issue with eem applet
EugeneL
When I am trying to configure a simple applet on the ISRG2 routers after entering the action for email, the variables end up being empty in the actual config
Here is what I am entering in the config mode
event manager applet bgp_detect
event syslog pattern "%BGP-*"
action 3.0 mail server "$_email_server" to "$_email_to" from "$_email_from" cc "$_email_cc" subject "BGP event" body "$_syslog_msg" source-interface Loopback0
The variables are defined in the global config, however with some of the newer codes like  15.7(3)M6 for example , after entering action command and looking at the config you end up with the empty string within quotes. Has anyone seen similar issue ? I end up with this in the config.
action 1.0 mail server "" to "" from "" cc "" subject ":" body ""source-interface Loopback0
Here are the versions
Embedded Event Manager Version 4.00
Component Versions:
eem: (rel9)1.3.0
eem-gold: (rel1)1.0.2
eem-call-home: (rel2)1.0.5
0 Replies 0
