I am trying to upgrade Cisco Works Resource Manager Essentials from 4.0.5 to 4.0.6 or higher. I understand I need to update Common Services 3.0.5 to 3.0.6 before hand. When I do this from the GUI I get the following message "No updates available in cco for selected products."
I can't find the update patch for RME 4.0.6 or Common Services 3.0.5 on the Cisco web either. Can anyone help?
The system is at LMS 2.6 with mdf 1.23 installed.
Thanks.
