Upgrading Catalyst 3560-E with LMS 4.0
arne.schwabe
I amt trying to upgrade a Catalyst WS-C3560E-24PD-S with LMS 4.0 and the Image c3560e-universalk9-mz.122-55.SE1.bin
. I can choose between flash(40/55 MB) and fstage (4/6.5 MB) but the upgrade process always fails with the fatals error:
Warning - SWIM1132: Selected image FeatureSet and Running Image FeatureSet are same.
Check Whether you really want to upgrade the device.
Catastrophic - SWIM1200:Selected Flash partition requires minimum (64 MB) to upgrade selected software/image.
Select a different Flash partition for upgrading the image.
The warning seems to be a bit bogus. Like it should have been "are not the same". But the real problem is the second error. The image in question is less than 20MB, so it should fit nicely on the flash. Upgrading the flash on the Switch is not possible either.
Joe Clarke
The problem is not the size of the image file, but its flash requirements.  Try increasing the value of MINFLASHPERCTOBEINC to 20 in NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/conf/swim/RecommendVerifyFields.properties, then re-run the job.
