Upgrading to Cisco ISE 3.1 from 2.7 patch 8 fails.
trondaker
Level 3
Level 3
Tried going from ISE 2.7 patch 8 to 3.1 via the bundle: ise-upgradebundle-2.6.x-3.0.x-to-3.1.0.518b.SPA.x86_64.tar.gz
When the secondary monitor/admin-node was restarted, the application ise cannot start with the following message:
x-ise-001/admin# application start ise
% Error: ISE Integrity Check Failed! One or more ISE program files appears to
% be tampered with. Check system log for specific error(s).
% Application failed to start
All health checks passed before starting the upgrade. I see the CSCwb70401 mentions something similar with patch 2, but that was not applied here, just the vanilla upgrade-bundle. Any hope of fixing this without TAC?
6 Replies 6
Mark Elsen
 - I don't know if the particular upgrade path is supported ; ref : https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-1/quickstart/guide/cpi_qsg.html#76503
   >...You can upgrade the following Prime Infrastructure versions to Prime Infrastructure 3.1:
  • Cisco Prime Infrastructure 3.0.3
  • Technology Package 1.0.3 for Cisco Prime Infrastructure 3.0.2
  • Cisco Prime Infrastructure 3.0.2
  • Cisco Prime Infrastructure 3.0.1
  • Cisco Prime Infrastructure 3.0.0.78
If your product/version is not in this list, to upgrade to 3.1, you must first upgrade to version 3.0.x at a minimum.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
 -Well then at least the two documents are conflicting , you could try 'via 3.0' first , hope you have full backup or vm-copy (e.g.) of the Prime environment you are working on (always advisable) .
 M.
       Beauty and terror
      Just keep going
       No feeling is final
trondaker
Level 3
Level 3
ISE, not Prime.
 - Sorry for that I got completely confused , the reason being that this group has usually has 'the Prime questions...' and not ISE...., you should post  the original question in https://community.cisco.com/t5/network-access-control/bd-p/discussions-network-access-control , I could move the thread but I will not do that now because it is already 'poised' and useful answers may no longer get appended. Post the 'native problem' again in there  ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
trondaker
Level 3
Level 3
Oh, im sorry, couldnt quite find the correct section - thank you.
