Uploading BGP MIB to HUM
cdorsch
I'm attempting to load BGP4-MIB.my which I downloaded into HUM (1.2.0 on Solaris). All the dependencies are there, but I get the following error
   " ERROR: Unable to serialize the object into database. Check if MIB details are  available in database"
Any idea how to deal with this?
Thnks
Conor
Joe Clarke
There were some MIB loading problems fixed in the recently release LMS 3.2 SP1 (which includes HUM 1.2.2).  I just tested locally, and I was able to load the BGP4-MIB just fine.  I suggest you try and upgrade, then see if you can load the MIB.  LMS 3.2 SP1 can be downloaded from http://www.cisco.com/cisco/software/release.html?mdfid=282635181&flowid=16561&softwareid=280775102&os=Solaris&release=3.2.1&relind=AVAILABLE&rellifecycle=&reltype=latest .
