URGENTLY HELP REQUIRED.
mkkhan786
Dear Friends,
our management want to know about 6509 restart cause...any one help me regarding this activity ..
we have lms 4.0
Last switchover reason = active unit failed
This is the reason.
5 Replies 5
Leo Laohoo
Post the complete output to the command "sh version".
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Versio
n 12.2(33)SXJ2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 14-Dec-11 19:51 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
 cc-cor-sw-01 uptime is 31 weeks, 5 days, 23 hours, 47 minutes
Uptime for this control processor is 5 hours, 29 minutes
Time since cc-cor-sw-01 switched to active is 5 hours, 5 minutes
System returned to ROM by Stateful Switchover at 14:18:48 UTC Wed Mar 7 2012 (SP
 by power on)
System image file is "sup-bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXJ2.bin
Last reload reason: reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.5) with 458720K/65536K bytes of m
emory.
Processor board ID SMC141700NW
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1 SSC-400 controller (1 IPSEC).
40 Virtual Ethernet interfaces
116 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Can you post the output to the command "sh red summary"?
Redundant System Information :
       Available system uptime = 32 weeks, 1 hour, 44 minutes
Switchovers system experienced = 2
              Standby failures = 0
                 Hardware Mode = Simplex
    Configured Redundancy Mode = sso
     Operating Redundancy Mode = sso
              Maintenance Mode = Disabled
                Communications = Down      Reason: Simplex mode
Current Processor Information :
               Active Location = slot 5
        Current Software state = ACTIVE
       Uptime in current state = 23 hours, 18 minutes
                 Image Version = Cisco IOS Software, s72033_rp Software (s72033_
rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXJ2, RELEASE SOFTWARE (fc4)
                          BOOT = sup-bootdisk:s72033-advipservicesk9_wan-mz.122-
33.SXJ2.bin,1;
        Configuration register = 0x2102
Peer (slot: unavailable) information is not available because it is in 'DISABLED
' state
This is the reason.
