using action info in applets
iParadigms.net
Community Member
So Cisco documents these perculiar $_info_foo_bar_[1-N] variables here:
http://www.cisco.com/en/US/docs/ios-xml/ios/eem/command/eem-cr-a1.html#wp8708912800
But give no example or tcl-esque action (such as subst/eval?) to actually use them in an applet!
Can someone demonstrate how to make this work in an applet:
event manager applet B0RK-ACTION-INFO
event none
action 1 info type cli history
action 2 puts "num entries: $_info_cli_hist_num_entries"
action 3 puts "first entry: $_info_cli_hist_cmd_1"
action 4 puts "last entry: $_info_cli_hist_cmd_$_info_cli_hist_num_entries" ! <-- b0rk b0rk b0rk
Output:
ios#event manager run B0RK-ACTION-INFO
num entries: 8
first entry: end
%HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: _info_cli_hist_cmd_
%HA_EM-3-FMPD_ERROR: Error executing applet B0RK-ACTION-INFO statement 4
Are these fools errand features? Of course one could write a tcl script. But that defeats the whole purpose of using the documented applet api.
../C
avayner
Level 3
Level 3
Curtis,
Unfortunatly EEM would not exapnd variable content to be used as part of the EEM syntax...
The only way I am aware you can accomplish what you tried to do is by generating a dynamic EEM applet...
The problem with this specific solution is that actually creating the child policies would break the cli history 😉
So it doesn't really do what you want... so just a nice concept for other similar things...
Something like this:
conf t
no event manager applet PARENT
event none
action 3.1 set entry "1"
action 3.2 cli command "enable"
action 3.3 cli command "conf t"
action 3.4 handle-error type ignore
action 4   while $entry le $_info_cli_hist_num_entries
action 4.01  cli command "event manager applet CHILD"
action 4.02  cli command "event none"
action 4.021 puts "  >>> ENTRY=$entry"
action 4.03  cli command "action 1 info type cli history"
action 4.04  cli command "action 2 set result $q \$_info_cli_hist_cmd_$entry $q"
action 4.05  cli command "action 3 context save key result_context variable result"
action 4.06  cli command "do event manager run CHILD"
!action 4.07  cli command "no event manager applet CHILD"
action 4.08 context retrieve key result_context variable result
action 4.09  puts "INFO-CLI-HIST-CMD-$entry = $result"
action 4.10  increment entry 1
action 5   end
end
event manager run PARENT
