using EEM to transfer file using SFTP
nikos_skalis
Hello All,
I would need your help about the following :
let's say that I have a file stored on "disk0a:/usr/" and it's name is "_debug.dat"
and I want to transfer that file using SSH to home directory "nikos" on the server "1.1.1.1" and the password would be "123abc!"
So, teh command would be :
sftp disk0a:/usr/_debug.dat nikos@1.1.1.1:/home/nikos/
then I'll be prompted for password, and the transfer will be completed.
My question is how to do that using Tcl/EEM and without be prompted for password ?
I know that there is a -force option, but I haven't made it working.
Kind Regards,
Nikos
6 Replies 6
Joe Clarke
You will always be prompted, but you can answer the prompt within EEM.  For example:
cli_write $cli(fd) "sftp disk0a:/usr/_debug.dat nikos@1.1.1.1:/home/nikos/"
cli_read_pattern $cli(fd) "password"
cli_write $cli(fd) "123abc!"
Thank you Joseph,
Here is what was written :
set    cmd "sftp disk0a:/usr/flow01_key
labmin@1.1.1.1:/home/labmin/
if [ catch {cli_write $clifd(fd) $cmd} rc ] {
        error $rc $errorInfo
if [ catch {cli_read_pattern $clifd(fd) "Password:"} rc ] {
if [ catch {cli_write $clifd(fd) "abc123!"} rc ] {
but, what I see in the logs is :
RP/0/RSP0/CPU0:Oct 19 10:47:48.012 CET: ssh[65866]: %SECURITY-SSHD-3-ERR_SYSDB_DELETE : sysdb_item_delete failed for tuple 28488010 in function ssh_kexinfo_tuple()
do you have any idea how to bypass this ?
This doesn't appear to be an EEM problem per se, but a problem with SSH on the device.  Unfortunately, I don't have an IOS-XR device with which to test, but I don't see any problem in this code (provided the sftp command prompt does contain the pattern "Password:").
I didn't think Cisco supported sftp?
Router#copy running-config ?
  archive:        Copy to archive: file system
  flash:          Copy to flash: file system
  ftp:            Copy to ftp: file system
  http:           Copy to http: file system
  https:          Copy to https: file system
  idconf          Load an IDConf configuration file
  null:           Copy to null: file system
  nvram:          Copy to nvram: file system
  rcp:            Copy to rcp: file system
  running-config  Update (merge with) current system configuration
  scp:            Copy to scp: file system
  startup-config  Copy to startup configuration
  syslog:         Copy to syslog: file system
  system:         Copy to system: file system
  tftp:           Copy to tftp: file system
  tmpsys:         Copy to tmpsys: file system
Thanks, Pat
The question here is about IOS-XR.
Oh, ok.
