Using Net show
lambay2000
Level 2
Level 2
when i create a Netshow job,it is always gives me failure status but when i click on the JOB ID to see workorder and then when i click failure it show me the command output.
pls suggest .
Joe Clarke
The way Netshow tries to detect a failure can be problematic.  That is, if the output contains certain keywords, Netshow will think the command failed when it actually did not.  Some of this was fixed in LMS 3.2, but the potential for a false positive could still exist.
